Discuss Vitodens 200 (Viessman) in the Central Heating Forum area at PlumbersForums.net
I have this boiler to heat and provide hot water for my home. I have had a total of three of these boilers. The first two were recalled by Viessman and replaced. The problems with the recalled boilers was I had to keep replacing ionization and ignition electrodes. There was also some risk of carbon monoxide leakage.
The last one was replaced in 04/2021. So it's been working fine for over a year. Recently (October 2022) it's been shutting off with error code EE (combustion failure) every day, sometimes multiple times per day. I just had my plumber come out (Nov 2022) and replace the ionization electrode for $300. The plumber said this is a constant problem with this boiler and be prepared for the failures to continue. I'm getting a bad feeling again about this boiler again.
I've been to Viessman's website where you can input your serial number and see if it's a recall boiler. My number (75547031010311120 -B2HB 160) was not a recall boiler for now.
I have a question if any customers or professional plumbers are aware of this issue and can share any advice?
Not heard of a persistant problem like this with the 200, might be worth contacting Viessman UK or Europe technical to see if they can shed any light.
Isn’t the boiler under warranty?
Reply to Vitodens 200 (Viessman) in the Central Heating Forum area at PlumbersForums.net
