Discuss 'Water Hammer' wav (sound) file examples? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
parisblue
does anyone have any recording or wav files
of 'water hammer'?
My problem (in my council) flat is the sound of
a rasping, vibrating, low whining/screeching/groaning 'Tuba' that lasts for
up to 2 seconds. It is horrible and keeps me awake night after night.
At first I thought it was the neighbour upstairs
dragging a heavy table across a wooden floor
(you know that dull screehy sound the table legs make as they resonate?)
but it isn't her after all.
The problem is - the sound is dependent on random
water usage/pressue/demands from the upper flats and it never occurs when the landlord in waiting in my flat to hear it.
Please let me know if anyone has any pre-recorded quality
water hammer sounds (like my description) so I can demonstrate to the landdlord what I am actually hearing.
I've searched the web but couldn't find any samples.
Many thanks,
Paris.
Don't you have a record function on your mobile phone?
It's not water hammer - that's a banging sound
The screeching is probably due to a worn out tap or cistern valve somewhere in the property.
I tried that, and tried a mic hooked to Windows sound recorder. Unfortunately the noise frequency is too low to be picked up fully by a mobile phone or any general sound recorder.
It needs a quality (sensitive) recorder capable of capturing sound around [FONT=Arial, Arial, Helvetica]40 Hz. (Thunder is around 30 Hz!)
Vibrations an rumbles are always difficult to record if you don' thave good sound recording equipment.
I'm hoping somebody has already done this.
[/FONT]
Try my website (click the link):
www.slumberlands.freeserve.co.uk/SinkTapWhine.wav
to hear an old brass sink tap whining and groaning when you run water from it. I just recorded it using an iPod. (The voice at the end - just after the trombone effect - is my wife asking me what the hell I'm doing - a nuther sort of whining and groaning!)
I think the noises are being produced by the vibrations of the jumper as the high-pressure water flows past it in this old and worn-out tap. I can vary the sound by adjusting the water flow.
Enjoy!
Thanks for that.
Initially I thought nah.. that's no the sound, that's just
a 'whiny' sound ..but then at 23 seconds that teeth grating almost indescribable *scvvvrrccrrrrroooaaarrccchhgghhagghagghrrrvvv* sound. *ugh*
It's so horrible I can't even spell it.
That's generally the sound I get, except from a mains pipe behind
my bedroom wall, so it is louder albeit muted, but just as annoying.
It's no laughing matter, but I did laugh at the thought of your wife
walking in whilst you're crouched under the taps..
..recording ..something dodgy!
"WHAT THE HELL ARE YOU DOING?!"
would be my question too!
Cheers.
I can't believe nobody records more of these sounds for referrence.
I imagine, people just want to forget all about it as soon as possible.
Reply to 'Water Hammer' wav (sound) file examples? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Locked
I have water hammer when I run cold water anywhere in my flat. I can only hear it in the cupboard that houses my OSO water tank that was fitted a...
7K
tackleburger
T
M
  • Locked
Hi Folks, I have an issue with water hammer occuring on all of my hot cand cold taps, washing machine, dishwasher and toilets. I have replaced the...
1K
ecowarm
E
  • Locked
We just install new combi boiler.Since than there is high hammering noise whenever open the and close the water taps.Even the noise is also at...
2K
Puddle
K
  • Locked
right, i have a problem. let me quickly explain. i had been getting bad water hammer, and presumed it was caused by a old vertical peice of pipe...
9K
k13 wjd
K
R
  • Locked
Hi, about six months ago a plumber installed a new Albion ultraseel 180 litre cylinder. The information on the commissioning information says I...
4K
RickF
R
