Discuss Water only from shower head in the USA area at PlumbersForums.net
Morning,
I have an issue with my bath faucet. It used to work fine, but all of a sudden when I run the taps, no water comes from the main bath faucets.
All water goes straight to the shower head, despite the diverter not being on.
Any ideas?
thanks
Diverter sticking, try wigglering the lever and shocking the valve body with a rubber mallet or piece of wood. It will only get worse and require taking it apart or replacing.
Reply to Water only from shower head in the USA area at PlumbersForums.net
Hi all I had a new bathroom fitted about 4 months ago and all was fine until about a week ago. But now when I turn the lever to run the rain head...
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are...
I’m wanting to replace the single handle cartridge on my basement shower since it no longer allows hot water (sink in same bathroom works fine). I...
DIYSAM
i can't tell if my shower tap (cock stop) is leaking or not ...............so after showering, the shower head will drip fast for 2 hours, then...
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
