Discuss water pipes & electrics in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dom38
:confused: can any one help me out? i am a bit uncertain about the distance of pipe work in relation to main electrical switches & circuits , i have been asked to fit a shower and the and the only way to do a neat job is to run the pipes next to a lightswitch is this allowed?
Hi. The problem might be drilling through a wire, if you clip the pipe to the wall.
The 17th Edition of the IEE Regs should tell you. Try Voltimum site. Just guessing of course, I would say yes its okay providing they are bonded.
You don't need clips!
I like to hear the pipes banging and watch them twang all over the place.
Came to have a look at a heating system yesterday. Large house and not a single clip in sight! The pump was suspended on a piece of wire slung up to a rail. The residents also commented that the system rumbled and rattled a lot.
Reply to water pipes & electrics in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated...
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the...
Essaboy
E
Hoping somebody can help, So, in a nutshell… Standard 90s Westbury home – condensing boiler, pump, wall thermostat, etc etc... Normal, common or...
Hi. I'm currently estimating on installing a new shower pump to feed an existing bath/shower diverter. Hot side: fit flange and spherical valve...
5K
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
