- Messages
- 34,379
- Solutions
- 2
your issue is not with hot water so the flange makes no difference
will as we don’t know what he’s done with the vent connection / will be pulling air into the pump
Discuss Water Pump Issue in the USA Plumbers Advice area at PlumbersForums.net
he said cold water side only..easy enough to test that thoughwill as we don’t know what he’s done with the vent connection / will be pulling air into the pump
i could just do one way valve for vent so would not be pulling air if thats the problemwill as we don’t know what he’s done with the vent connection / will be pulling air into the pump
so replace air with a vacuum LOL not a good idea. You don't have enough water through the cold side (you said it was cold side right!) so you create an operational work around (only use the pump in isolation) or you find a permanent solution. I hate this man but it does show what is neededi could just do one way valve for vent so would not be pulling air if thats the problem
i was looking his video on how to install the pumpso replace air with a vacuum LOL not a good idea. You don't have enough water through the cold side (you said it was cold side right!) so you create an operational work around (only use the pump in isolation) or you find a permanent solution. I hate this man but it does show what is needed
in my city plumbers there is no really good plumber they might suggest to replace water cylinder DOp please get a pro in before you do something bad
but he’s boosting both hot and cold
so hot side need a flange else pump will wear quick due to oxygen being pulling in / could air lock
cold side ball valve isn’t rated for mains pressure will have a gravity nozzle in
wow, prone to the dramtic are we lol a bomb...how silly are you.no no no that’s a bomb
LOLif he puts a nrv on the vent yes it’s a bomb
that's a good drawing...
Reply to Water Pump Issue in the USA Plumbers Advice area at PlumbersForums.net
