Discuss Water regs with NVQ level 3 in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Matt0029
I got my water regs when I completed my NVQ level 3, in 2017. Do you have to renew this every year?
Not to my knowledge you can do a refresher course if you need to but tbh not much updates year to year
Reply to Water regs with NVQ level 3 in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The front right corner shim is 5/8", the left front corner is 3/8" shimmed, with shorter shims under left middle and right rear corner. The pan perimeters...
