Discuss weather compensator with comfort II stat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
does anyone know if you can fit a worcs weather compensator and it work with the comfort II thermostat, is it just a matter of sighting the weather compensator out side and fitting the wire/ plug to the board and then it "does its thing"?
Reply to weather compensator with comfort II stat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
