Discuss weeping solder joint under drain off level, in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
that bloke.
can a solder joint be re-soldered if there is water in the pipe? ive often heard people say it can but ive never tried , ive got a weeping solder joint below the drain off valve.
agree with GM you cannot solder a joint with water in the pipes, most people have tried this at some stage just to test this out, if you are worried and don't want to drain down then just freeze the pipe, drain and re solder.
do what i have seen a few times this week,
slap some super glue on it.lol.
Why would they even try? It's obvious that the temperature of the tube isn't going to exceed 100 deg. C., while the solder we use will have a melting temperature in excess of 200 deg. C.
that i couldn't tell you, but when i was learning our tutor made us do it so everybody understood that it couldn't be done
The Guys (or Gals) are right canna be done ..... Just cut through the fitting and get the water out and then unsolder the fitting & replace or just cut it out and use a compression fitting .. simples!!!
cheers guys , thought it was a long shot. just cracked the seal on the stopcock and drained down from there then replaced the fitting with a new drain off valve.
Reply to weeping solder joint under drain off level, in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with...
1K
Hi, I am probably being unduly paranoid here but I noticed under our kitchen sink that there is some corrosion evident on a small section of...
J
I have an Arteform shower valve in my bathroom - top lever for the main shower head, middle for the handheld hose and bottom is the thermostatic...
Hi All After having pooling water on my drive, I dug down around to find: Black pipe poly/plastic dug 450mm deep spraying water at mains...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
