Discuss Weird Water Pressure on Mains in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jaydebruyne
I went to a job today of a lady complaining about the hot and cold water pressure.. She said every now and then both hot and cold stops completely then comes back on.
Naturally I think it's a gravity system and either a ballvalve issue or an air lock of some sort, or maybe a pump.
I get there and it's all on mains with a worcester 24ri jnr combi boiler.
WTF????
When I was there, the hot and cold from the kitchen tap stopped completely. 5 minutes later it's back on.
This happens to all appliances (2 showers, 1 toilet/basin and kitchen sink).
It's been going on for about a month now.
There is a storage tank on the roof but I've traced the pipes and I think it's serving the flat below her. She's on the second floor of a very small block of flats.
Any ideas?
Failing pump somewhere? Contact water board?
if its doing it on the cold as well contact water board
Have you ever known this issue before regarding the water board?
yes but i was a big complex water main (main) wasnt big enough at peak times down to dribble/off for upstairs
Did you check the internal stopcock ? could be washer moving around and stopping water, does it only happen in this flat or the others as well ??
It's a lever valve.. so shouldn't be causing an issue.. nobody was in downstairs so will be going back... Water board just said there may be a pump on ground floor so will check that also...
Reply to Weird Water Pressure on Mains in the Plumbing Jobs | The Job-board area at PlumbersForums.net
