Discuss Wetroom tiles squelching and bringing up water in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
M
Mark__
Hi all
Moved in to a new house a few months ago. The previous owner had installed an accessible wetroom with nonslip flooring, handrails, etc. We've been using it but have started to notice that some of the floor tiles make a squelching sound when you tread on them and a little water emerges from between the tiles. I'm sure that's not what is meant to happen! It also looks like there are some wet marks on the ceiling below. So we've stopped using it for now.
I'm a complete novice so would appreciate any advice about what we could do. Is it possible that regrouting is all that's needed? Or does it need a more thorough inspection? Do we need a tiler or a specialist wetroom installer to sort this out? Help!
It’s fecked and needs to be ripped out and started again sorry to say
The very least is take up the loose tiles and redo, but it’s not a good sign and usually means that nothing has been done properly and it usually ends up as a rip out and redo.
Reply to Wetroom tiles squelching and bringing up water in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
Hello hello,, Hoping there are some experts or experienced Bulgarian plumbing chaps in this site ?. Here in the UK I can fit a bathroom just with...
We have just moved in to a 1934 Semi- and I am getting round a few simple DIY tasks, including a couple of plumbing-part renewals such as modern...
Hi all, We've got a toilet that's been leaking due to a faulty seal with the pan connector. We've had a plumber in to replace the pan connector...
