Discuss What a nightmare in my eyes... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
There is only 10cm sticking out right underneath the rain gutter. I was sure there was a ref for a certain distance. The Worcester engineer had a look and said it's fine. He seemed in rush but did his job in full. Checked, operating pressure , flue gas analysed it, checked the fan. But fail to do a tightness test just walked in and started his job.
Yes Worcester came today, without tightness test. Started his job checked the pump. He took the pump head off and was completely not moveable. However, once I used a little screwdriver I freed it and it worked fine. He still changed the pump and did his tests as explained above. He wasn't really happy with the flue either neither the pipework. He said it isn't great ... I said it's awful ... thanks for coming back guys !!!No excuse for bad workmanship Ronny needs sorting out bud get the installer back did Worcester sort out the fault ?
Cheers kop
Ah ok, I thought everyone working on a gas appliance should undertake such a important step.He is not required to tightness test
Yes have paid already in full and he keeps asking me to leave him a review. It I will explain to him today ( as I am not a pick ) that is not what he really wants as it will ruin his business.Have you paid?
Maybe request a free gas safe inspection
I was still happy with the way he checked and worked at the boiler but the aftercare ... don't ask me ... never again ... learned the hard way again!!!He's not working on the gas line
If he was replacing the gas valve he would only have to test from the boiler valve to the new gas valve
After I mentioned it and he inspected the flue he took some screws and screwed it down. He can not leave it like this that's what he mentioned. I believe he has noted it on his laptop.Did the Worcester guy screw down the flue or leave it?
Thanks Scott,Tell him Worcester fixed the pump but 'at risked' the boiler due to the poorly fitted flue. You had to pay someone else to sort out the flue.
Ronny the guy screwed you over problem is you need him to register it and complete the benchmark so probably going put up with it , i would not let him do anything else for you but your choice. Kop
How are they different hole is a hole,
me personally I would ar it
That's the only hong they have filled out now . I'm still here and I'll make ute I won't use this guy again.
What can I do ? They want to leave the casing off because they need to take the kitchen cupboard off and it's late they leave the boiler on with full electricity they said it's fineThose figures on the benchmark are made up. 29ppm and 9.3% don't give a 0.0008 ratio.
Just going home and will answer in 2 minWhat do you guys make of the benchmark ? filled in sitting in the van i bet ,You have named and shamed him now Ronny i would edit that bud while you can. Kop
Here that's the way they left itJust going home and will answer in 2 min
It is already registered as he had to call them last week and they have asked about the address and what boiler it etc,.. I will call them tomorrow and will ask if the boiler has been registered. I will hunt it down trust me there.What do you guys make of the benchmark ? filled in sitting in the van i bet ,You have named and shamed him now Ronny i would edit that bud while you can its a tricky situation you have got yourself in tread carefully mate its not registered until he does it with gas safe . Kop
The installer Shaun have a look at the benchmark those figures are not right and there things missing wheres the print offs of flue gas analysis i staple them to the benchmark .
Worcester had left it too like this but they have isolated electrics and gas.who left it Worcester?
??? What you mean ????Something doesn't add up here
Reply to What a nightmare in my eyes... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
