- Messages
- 5,439
My mum recently moved into a bungalow. Starts getting high water bills. They then tell her she's averaging 500 litres used a day so I go to investigate.
No obvious leaks. It's a combi so could only be hot and cold leaking and it's solid floors with no pipes (that I can tell from initial snooping) in the floor at all. All pipes seem to be run up and down from loft with a few running behind boxing here and there. No damp patches, mould, no sounds of water/drips, checked usual stuff like inlet/drop valves, outside taps, behind washing machine.
I looked at meter when nothing being used and it was moving very slowly
I told her to take readings over periods of time when not using it to see how much 'usage' the leak was accounting for. But this is when it got confusing. ..
Yesterday she was out of the house during the day for 10 hours and it registered 40 litres had been used on the meter while she was away. However the day before - overnight for 12 hours - the water wasn't used and it registered no change. Zero movement, exactly same reading as 12 hours previously.
Bit of a weird leak that can do that? Faulty meter? Just wondering if this points to something before I start removing boxing, looking further.
