- Messages
- 5,439
After turning cold on and then off there is a 2 sec gap then for a few seconds more water comes out. Not just a few drips, not full force, somewhere in the middle. Not every time but most times.
On swan neck taps where this happens I have presumed it's water left in spout and a bit of syphonage happening. But on this tap (new, fitted by me, recently) the spout angles slightly back which I thought would discourage this and more importantly it only does it on the cold, not the hot. Futhermore it's fed from a combi so should be equal pressure?
Previous tap (near identical style, prob diff make) didn't do it.
The water doesn't mix in the spout. The hot comes from separate part of the tap that seems to be the middle of the spout, the cold from the outer part of the spout.
I have not tested the pressure. The tap is listed as having a max pressure of 4 bar. But if it was a pressure issue wouldn't it effect the hot too as its a combi? Plus it shuts off fine. It seems more like the water left in the spout is coming out, but could be wrong.
I changed the ceramic valve to another one I had on van and it did the same.
I can contact company but wanted unbiased opinions on the cause first. My guess is the larger apeture from which the cold comes is just over whatever threshold is needed for some syphonage to occur from the last few drips.
I thought (after leaving) I could have swapped hot and cold feeds round and see if it just does it from hot now. I also thought I could try fit a different aerator which requires more force for water get through.
