Discuss What might make combi produce low dhw flow? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The strainer is inside the boiler
Flow restrictors may be inside the isolation valves for each tap
Probably scaled up heat exchanger
That's where I was heading, could even be a scaled up inline scale reducer. The long chrome thing on the left. Or has someone part turned off the flow valve to the boiler?
Would a scaled up inline scale reducer just reduce hot flow, normally? I can check that one.
I can't do anything within boiler as not GSR.
Will check there aren't flow reducer on iso's to taps.
Given the boiler then if I managed to increase the flow would it suddenly struggle to keep water hot if taps turned on too much? At the moment water nice and hot. As I said my mum isn't too bothered and don't want to swap one problem for another but would like to increase her hot flow if I could, mainly because filling a bath would currently take a month.
WT , yep bin the scale reducer ( at least for now) , only other thing is the flow turbine in the boiler could be prone to crud , but you would need to go in the boiler for that .
Divide the Kw rating of boiler by 3 to get expected flow in litres/min.
24Kw should give 8 litres/min. If you can confirm cold water flow to boiler exceeds 8 litres/min then problem is most likely scaled up domestic hot water heat X. Could be faulty diverter valve but in hard water area any heatX more than 6 years old is worth replacing even if problem is elsewhere. Need to be GSR.
I had one with a similar problem i had to strip down the whole hyroblock and clean it out as it had not been used for over a year there was a obstruction once removed all was ok 9-10 litres a minute regards kop
Reply to What might make combi produce low dhw flow? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
