What parts do I need to replace this 40mm setup? I'm thinking of cutting the pipe to the right and replace the rotten part with a flexible connection. The T goes into a ceramic drain pipe.
Discuss What parts do I need to buy to replace drain situation? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Thank you so much!Flexible double waste adapter
Length of 40mm solvent weld pipe
2x 40mm bends
1x 40mm socket
Solvent glue
Reply to What parts do I need to buy to replace drain situation? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
