Discuss What should the fall be for waste pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Guys
I’ve a few questions and hope someone out there can help, all are for a domestic system not commercial.
What is the minimum and what is the preferred fall ratio for a toilet waste 110mm pipe?
I understand if its too steep solids can be left behind in the pipe, likewise if its too slight a fall.
What is the minimum and what is the preferred fall ratio for each of the following:
Basin waste 1¼" / 32mm pipe
Bath waste 1½" / 40mm pipe
Shower waste 1½" / 40mm pipe
My thanks to anyone who can help
Hi Guys
All of what you should need answers to should be in here.
Approved Document H | Part H - Drainage and Waste Disposal | Planning Portal
By the book its Basin 32 = 22mm /m (max1.7m run to stack)
Bath or shower 40 = 18 -90 mm/m max 3m to stack
It's the longer 110mm runs that fall is critical.
Deburring and smooth transition also important as fall imo
11/4-2” 15mm a m
4” 15mm- 25mm a m depending on if your fixed by anything
11/4-2” 15mm a m
Cant decide if that helps morningcloud or not.:eek:
Mine are plumbing spec eg 1-40 and 1-110
Reply to What should the fall be for waste pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
