Discuss Where can I buy this exact isolation/service valve? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
The isolation valve connected directly to our toilet fill valve has started to leak (I assume the washer has deteriorated). I'd like to get a like-for-like replacement so that I can just do a straight swap of the entire isolation valve without having to worry about resizing pipes, but my google skills have failed me (I'm a DIYer/Homeowner so not sure exactly what I should be searching for). Does anyone know where I can find this exact model? If not, can someone recommend a similar one I can use in its place?
Picture is from another user who posted a thread on this back in 2017, but I have this exact same valve.
its called a straight service valve. It will be 1/2" one end 15mm the other, basically what I link below but not the same one.
I doubt you'll find an exact copy though. You'll need to get a 15mm pipe slice and some jointing compound an adjustable spanner and grips.
Just change the washer 1/2 fibre / hep 20 1/2 washer
Reply to Where can I buy this exact isolation/service valve? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
My son has an apprenticeship interview for to become a plumber and heating engineer. The have said there will be a multiple choice exam for this...
