Discuss Where does your forum username come from? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello stranger how are you Peter....hope you are well did you ever get round to finishing your DVD on lead work....be lucky regards Turnpin:)
Thanks for your thoughts Turnpin, in answer to your question no. My motivation is waning, although 90% is on film, i dither with this bit and that bit. Unable to complete. Perhaps another winter will improve moral. You will see more of me on the forum as i will be doing a bit of marketing here. As i have been lucky enough to have skilled labour that giving me more time to manage the selling side. Catch up soon.
Wishing you luck, Just Lead
... I don't think lead actually attracts much interest from rats...
Cheers , more of an A to B thing.
Brick wall in way , with a hole in it , hole is filled by chewable pipe ....
Seen that in plastic a few times !
Reply to Where does your forum username come from? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've got a Glowworm Flexicom 24hx boiler and I'm trying to unplug the installer cartridge in order to wire up the ebus connection inside. From...
Hi , i'm new to this forum & would like some advice , i have an upstairs bathroom & was wondering if i could put a cloackroom loo downstairs , my...
1K
The isolation valve connected directly to our toilet fill valve has started to leak (I assume the washer has deteriorated). I'd like to get a...
Evening all. Not sure if this is the most appropriate place to post this in the forum, happy to move if not. I'm looking for a metallic 32mm...
Hi all, I keep reading about how you should use a smart thermostat. Set it to the temp to want the home to be and hey presto it takes care of...
