Discuss Where should I connect my garden tap pipe? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi everyone,
I'm about to install a garden tap pipe on a new build, but I'm a bit confused with the pipework I'm seeing under the kitchen sink. Here is a picture of what I'm seeing:
  • Pipe A - Cold water pipe.
  • Pipe B - Behind the wood plank, B connects to a valve that shuts down the entire water flow. I suppose this is the main water pipe.
  • Pipe C - This pipe leads back in into the wall.
  • Pipe D - Hot water pipe.
Can anyone help me understand what is pipe C and where is it going? If I were to install a garden tap, where would I place a Tee fitting? on pipe A or would I swap one of those elbows leading to pipe C with a Tee fitting and use that?
Thank you
Are you in a hard water area? If so, my guess is that the original plan was for B to be the hard-water feed to a softener (or perhaps a filter) and C was to receive the treated water. The kitchen tap has to be supplied direct from the (unsoftened) mains.
You don't want to supply a garden tap with softened water, so I'd take it from the 'B' side rather than the 'C' side in case someone ever does want to install a softener.
Professional plumbers don't use brass compression-fittings without good reason. Perhaps the spec changed late in the day and there wasn't space to get a torch or press in?
All speculation, of course, but I do love a puzzle.
Should I solder compression fittings or would you say closing them tight should be enough?
Nothing wrong with using compression if you can't solder or circumstances dictate.
If you are confident, can solder and have the kit fine. I'd probably replace that double elbow union while adding the external tap connection just because, well it looks so wrong. Just bare in mind there'll probably be some sitting water in the vertial pipes if you can't drain or vac it out and that'll affect your ability to solder it.
Reply to Where should I connect my garden tap pipe? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Sonya K
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
