Discuss Which insert for poly onto Peglar pushfit 90's in the Plumbing Jobs | The Job-board area at PlumbersForums.net
As the title suggests - I am converting my rads to centre exit 10mm speedfit pipe, feeding into Peglar pushfit 90's which are mounted to the TRV. The question is which insert to use? I am using the basic inserts with no rubbers for the compression fitting but have both types in my toolbox...
I also gather that once the pipe is inserted into the 90's, its irretrievable? (not that it would need to come out.
Tim
Reply to Which insert for poly onto Peglar pushfit 90's in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it...
