Discuss Why does a 3/8" bush cistern lever actually measure 6/8" in diameter? in the DIY Plumbing Forum area at PlumbersForums.net
Or does the 3/8" refer to the radius of the bush, not the diameter?
It may be due to when the pipe sizes were determined (steel pipe) the internal bore of the pipe decided the pipe size.
Most, if not all steel pipe is measured ID.
So you have the wall thickness of the pipe which determined the thread size.
Reply to Why does a 3/8" bush cistern lever actually measure 6/8" in diameter? in the DIY Plumbing Forum area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The front right corner shim is 5/8", the left front corner is 3/8" shimmed, with shorter shims under left middle and right rear corner. The pan perimeters...
