Discuss Why is Rad. Feed not as Hot as Flow Temp I've Set? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Why is the radiator feed approx. 24degC just beyond/out of the Vaillant gas boiler (and also at the first radiator), when I've set the flow temp to 53degC? With boiler firing, the 53deg setting is always flashing on and off on the display - does this mean it never actually gets to 53?
Thanks!
Sounds like it’s trying to modulate the burner low enough for the flow is the flame symbol constant or going on and off ?
Reply to Why is Rad. Feed not as Hot as Flow Temp I've Set? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Sonya K
