Discuss Why should lowest branch connection be at least 450 mm from invert? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Shevek
UK drainage regs say: "for single dwellings up to three storeys high, the distance between the centre line of the lowest branch connection and the invert of the drainshould be at least 450mm."
What's the technical reason for this?
prevents back pressure. which is a pressure build up of compressed air at the foot of the stack which could cause trap seals to fail
Reply to Why should lowest branch connection be at least 450 mm from invert? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
Sonya K
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
I have a brand new, unboxed shower/wet room screen from KRION purchased from Porcelanosa UK. It is the Attica 1 model, as shown in the attached...
Sebastian T
