plumdum
Hi, fixing a copper pipe to lead pipe involves a 'wiped joint'.
But how do you do a wiped joint properly?
thanks.
thanks.
Discuss wiped lead joint in the Plumbing Jobs | The Job-board area at PlumbersForums.net
You are quite OK to do wiped lead joints for non-drinking water applications.
Forget leadloks - try the new Philmac universal coupling - far easier.
The following is a simplified description of joining lead to copper. It is somewhat of a skill which requires practice, and in reality is only done today in the chemical industry.
WIPED LEAD JOINT -
Clean inside the lead pipe and open up the end of the bore so it fits neatly over the 15mm copper pipe. Clean again with wire brush so it is bright.
Clean the outside of the copper pipe and apply flux (traditional paste flux) to both the inside of the lead pipe and the outside of the copper pipe.
Knock the copper pipe into the lead (the copper end needs to be turned over around the edge
Heat the whole area evenly then concentrate more on the copper, applying solder (leaded, lower melting point solder) to the joint.
Make sure the joint is full of solder and as much as it will take.
Clean off with wire wool.
no one has even mentioned cardwire and black or a turnpin or a shave hookHi, fixing a copper pipe to lead pipe involves a 'wiped joint'.
thanks.
Reply to wiped lead joint in the Plumbing Jobs | The Job-board area at PlumbersForums.net
