Discuss Wirsbo/ uponor pipe repair in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
Hi All. I hope you're well.
I need a bit of advice. Someone is having their engineered floor replaced which was installed 20yrs ago with underfloor heating. As the flooring people were taking up the old board they noticed a pipe came up with it. It has had a nail through it for 20yrs with no leak. Quite amazing really.
Any way, I need a part that will fix it tomorrow as the new floor is basically installed and ready for sanding and staining for new people to move in on Tuesday.
Problem is, it takes 2-3 days for the parts from Wolesey and I don't know anyone else that stocks them
Anyone know who will have these in stock?
These are the parts needed: uponor 1006641, uponor 1065290
Any guidance would be great.
Cheers
16mm mut ?
20mm Shaun
Problem is it's old these days it's 16mm
If the wall is 2mm thick which I can see it being they will work
Pressure test after repair
It says 20 x 2mm on the side of pipe in the picture.
Scary though burying it when Uponor say no. If it goes wrong it is costly
Dopey me didn't see :D
Pressure test to 6 bar if it holds its golden
Reply to Wirsbo/ uponor pipe repair in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Hello, hoping someone can advise me. My boiler stopped working - no hot water or central heating. Called out a company who came and assessed the problem as being that the hot water element in the immersion tank needed replacing. (I don't know exactly what it is called as the company has still...
J
Johnno1966
J
J
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the depth of my cupboard is larger than this. The issue, however, is that the waste pipe which leads from the sink (next door cupboard) comes out quite a...
