K
keith lancer
Hi. I live in Portugal and have just had fitted a well known English made wood burner with back boiler and central heating system. The system gets warm but not hot, the same with the domestic water. The system seems to cycle very quickly, domestic pump kicks in at 46 and ch pump at 55deg. The heat goes up to 57deg then drops back to 46deg so nothing really gets hot. This happens over 8 or ten minutes and repeats. I AM NOT A PLUMBER but as language is a problem any help would be very well recieved. I do understand that a flue damper needs to be fitted I understand the safety issues but is this likely to be a control problem? Ant suggestions would help
