Discuss Worcester 28i hot water OK, but intermittent c heating fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
pclimie
This has happened about once a fortnight over last 2 months now:
If I try and switch on my central heating within a few hours of it previously being on I get nothing, no heat, no attempt to come on. (The trip button has not triggered on top of the boiler)
I get hot water fine - anytime.
If I just leave it to come on next morning it comes on fine.
It's like something is overheating??
Any suggestions or advice gratefully received.
do u get heating if turn it on manualy at the boiler
No. If I manually turn on the heating it wont come one. This is the problem.
If I leave off, and try after 4 or 5 hours it will work manually eventually! Or leave till the timer brings on in the morning it comes on.
Reply to Worcester 28i hot water OK, but intermittent c heating fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
Hi there, My boiler (Worcester Greenstar Ri) has started making a soft knocking noise when it turns on, and again a few times when it turns off...
Customer complains of Intermittent heating on Y plan with Stat satisfied. New boiler fitted last year (no permanent live required or fitted...
2K
J
Hello, hoping someone can advise me. My boiler stopped working - no hot water or central heating. Called out a company who came and assessed the...
Good Afternoon all, I am hopeful someone may be able to offer some guidance on the following. In the home we have a gas boiler (serviced...
