Discuss Worcester 30CDi NG to LPG in the Gas Engineers Forum area at PlumbersForums.net
Leeukguy
Hi All,
Wondering if someone can give me some advice.... Recently removed a healthy 30CDi Natural gas from a house and put it into my caravan... Obtained correct conversion kit from worcester which was just a chip.. I replaced the existing chip for new, adjusted air/ratio as instructed. Turned boiler on and i then immediately switched off as a loud ignition followed. Anybody experienced this going from NG to LPG?
thanks
Did you fga it ?
Did you reset the gas valve to lpg spec ?
Nope you should of adjusted the gas valve
Reply to Worcester 30CDi NG to LPG in the Gas Engineers Forum area at PlumbersForums.net
I don't work now due to being ancient. I looked at a 'Range cooker' fired on kero. It had a slow leak that turned into a bad leak in a month! It...
2K
Hello again all: Firstly: Personal background, as I know people are likely to ask: 1) I AM GSR 2) Most of my work so far since qualification has...
  • Locked
Hello forum, my first post. I'm sure you get this all the time, but to come clean I am not Gas safe, I am not a plumber. But I am a mechanic and...
2K
Dotty
  • Locked
Hi All, I would really appreciate some help/advise with aboiler problem I am having. I have a valiant eco tec combi boiler and have noticed...
2K
brooklyn07
T
  • Locked
Hi All, Thought I'd better come to a forum to get some advice, as to be honest I feel like I'm going a bit crosseyed with the advice so far from...
6K
PlumbBobBob
