Discuss Worcester boiler heating water and CH in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
whiskeyfrank
I have a Worcester Danesmoor 15/19 oil boiler, its got an electronic timer module.
Lat year we had the boiler moved from one room to another as its noisy and gets in the way.
The problem is:
When the central heating is on the water heating is always on as well, we get red hot water all the time, even if you turn the water off on the panel the light stays on and the water gets hotter.
We can heat the water when the heating is off.
Our problem is we have electric showers, cold feed on the washing machine and dishwashers, so don’t use much hot water.
Before the boiler was moved we could turn the water off independently of the heating and only put the water on for 10 mins a day to keep it warm, now its on with the heating for 6 hours and its almost boiling. If you press the button on the WH side it points to off but stays on all the time, even with the timer set.
Worcester have said that it needs a new “motor diverter valve”, but my plumber reckons its doesn’t have one and never has. He also reckons that all they did was move the boiler and recoonect the pipes nothing else.
I do trust the plumber hes a good guy ive known for years and the only one in the areas who can do oil boilers.
Im at deadlock – any ideas anyone.
a danesmoor is a boiler only, ie heating unit. if you are having probs with external controls, ie no ch. no dhw, you have to look at your control system. it must have a divertor valve or 2 zone valves , called y plan or s plan.
Reply to Worcester boiler heating water and CH in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
Hi, We moved into a new property yesterday and are a little baffled by the heating/water tank situation. The previous owners unhelpfully left any...
Hi, Over the past few months, my wife and I have noticed a constant pulsing sound throughout the house which is particularly noisy at night (this...
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On...
Context for issue: Last winter the temperature switch on my boiler shorted somehow, the boiler was then running WAY too hot and ended up...
