Discuss Worcester boiler not working and flashing 'EA' error code in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My Worcester Greenstar 29 CDI boiler made a loud bang earlier today, and has now stopped working.
It is flashing the 'EA' error code, which according to the manual, means no flame is being detected.
I tried resetting the boiler a couple of times but upon doing so, it just makes an extremely loud vibrating/humming noise intermittently, and then turns off and flashes the EA error code again.
Could anyone advise what the issue is? Boiler is only 3 years old. According to the manual, the EA code means either no gas in the house, frozen condensate pipe or blocked flue outlet.
Wondering if this is something I could fix myself or if I need a gas safe engineer to come and have a look
Under warranty min 5 years if you have gas and power time to call Worcester out
You can fix yourself if it’s a lack of gas, by which I mean if you have a top up meter and have ran out, or Network has been turned off.
Anything else gas engineer/Worcester warranty required.
Edit: Check your emergency control valve - been to 2 recently where they had been accidentally knocked off.
Reply to Worcester boiler not working and flashing 'EA' error code in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, My mum has a Worcester Greenstar HE30 boiler (15+ years old). Since its last service (and possibly coincidentally) it has been making a...
2K
Condensing boiler installed by local Gas Safe plumber in 2014, not combi. Failed a couple of weeks ago with flashing blue light which googling...
4K
Hi I am new to this forum and looking for some help with an annoying issue with my Worcester CDi boiler ( installed about 2010 ). It provides...
2K
I have an 18mth old ecoTec plus 825 Vaillant boiler. We have had intermittent problems with the hot water supply for the last 2 days - now there...
2K
Hi Can anyone help? I've got a problem with an intermittent EA fault on a Worcester Greenstar 38CDi Classic GC 47-406-38. I was called out to it...
3K
