Discuss Worcester CDi error code in the Central Heating Forum area at PlumbersForums.net
Hi
I am new to this forum and looking for some help with an annoying issue with my Worcester CDi boiler ( installed about 2010 ). It provides heating and hot water ( through a separate lagged water tank).
Over a year ago it started going into a mode for a number of minutes before it then started running properly and it now does this pretty much every time the timer starts it...regardless if it's heating water, rads or both.
A number of call outs to British Gas I get told it's just normal and to do with syphon mode....but after multiple web searches I understand what error code is displayed when the boiler is in syphon mode....it looks like a bit like this.... '=||='...this is not the error code I get when it's in this mode. The error code displayed looks like the pic attached
Which flashes on and off. The boiler waits for a period of time before kicking in again and then stops and displays the error and cycles like this for up to 30min sometimes before it goes into normal operation.
I have tried in vain to find any reference to this error code and I keep getting palmed off by British Gas that it's normal operation....but if normal means I put the hot water on for 45min in the morning and it takes 30min to get started that doesn't feel very normal.
Any help from friends on this forum would be greatly appreciated, even if it's to tell me I need a new boiler!...any links to sites that identify the error code would also be appreciated.
Kind regards
Martin
Hi
A number of call outs to British Gas I get told it's just normal and to do with syphon mode....but after multiple web searches I understand what error code is displayed when the boiler is in syphon mode....it looks like a bit like this.. '=||='...this is not the error code I get when it's in this mode. The error code displayed looks like the pic attachedView attachment 45877
does the boiler have perm power eg where the error is displayed this has numbers in even when the heating or hot water isn’t on?
So the little led display is always live / got numbers on it ?
Re photo....hopefully attached now
Regards
MartinView attachment 45881
that’s the temperature is rising too fast normally sometimes errors on e9 as well
[automerge]1603393441[/automerge]
Moved posts to your own thread saves moving up different threads
Maybe unrelated, but when the CDIs first came to the UK they had a service interval indicator that needed to be reset in a certain manor. But I can't remember the symbols it did or the procedure to reset it.....
I’ve had a couple of boilers with these symptoms turning out be either a genuine pump tiring resulting in overheat or PCB fault. Needs gas safe engineer.
Reply to Worcester CDi error code in the Central Heating Forum area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
PSxxxxxx
