Discuss worcester boiler problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
danzil
Hi all
I was wondering if any body could help i have a worcester boiler, when you turn on the tap for hot water the pressure gauge starts jumping and the flow temprature goes sky high and the boiler starts banging, this does not happen all the time but it is more often than not, i was wondering if anybody has come across this problem.
Thanks Danzil
Sounds that maybe your pump is on its way out or a blockage,but if not happpening all the time,most likely the pump
Hi, this is Worcester, Bosch Group
Although we cannot offer live online help, our technical support team can help to answer your query, please call them on 0844 892 3366
Our plumber tried ringing you what you suggested didnt work we are getting quite frustrated now as it is happening alot now any ideas on who could help
had a similar problem with a new boiler, worcester, which i installed last year. system had been correctly cleaned and power flushed but i reckon some bits were blocking the pump/boiler. banging occured a few times so drained down and flushed thro again and it has cleared the problem up for 10 months now
Reply to worcester boiler problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
