Discuss worcester bosch 350 programmer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
- Status
Hi guys. For those of us that are still involved in one way or another with these combis, heres a workround if youve got a timer/programmer that has a flat battery. The problem with a flat battery is as you know in the event of a power disconection the programmer losses its settings and everything has to be reset. A new programmer if you can get one is around £120, or you can by a new battery and try and solder it in for about £15. Once i had determined the charging voltage was still there I purchased an "AA" battery holder from maplin for 90p and used a RECHARGEABLE 1.2v Ni-MH battery , like the ones you get in the solar lanterns and the like. I snipped one leg off the battery on the board so it would no longer be connected and soldered the battery holder wires onto the respective connections. This has been working fine for over six months with no heat issues or other side effects. I know some will say," just go out and buy a programmer".... the choice is yours.
- Status
Reply to worcester bosch 350 programmer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My son has an apprenticeship interview for to become a plumber and heating engineer. The have said there will be a multiple choice exam for this...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking?
This originally happened about 12 months ago and has happened 3-4...
