Discuss Y Strainer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jaydebruyne
Do these restrict flow at all? Someone has fitted 2 x 22mm strainers before a 3 bar shower pump and just wondered if they could be restricting flow (under normal use, not blocked with debris).
If there are now 2 different filters in a line then surely there will a slight loss.
Sorry, bad explanation, so there's one on each cold and hot supply..
No (if anything won't be much )
Changed hose to a large bore hose and new showerhead and custard was happy ;) happy days.. Cheers lads
Reply to Y Strainer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have 3 port value for HW & CH. Loft extension added many years ago so they added a T to go upstairs, only 2 rads up but 11 downstairs covering at leave twice the floor area As per diagram has free flow Up or Down, no way to balance. Works pretty well but last few Rads (in kitchen) are...
Hi, We have a large Heatrea Sadia unvented hot water tank, not sure of the size in liters but its about 1600mm tall. The tank is around 3 years old now and was amazing when it was first installed. Around a year ago we had a problem with water dripping from the overflow pipe outside and we ended...
Hi all. As the title says, I have a problem with an unvented cylinder I had installed last year where the first time I turn a hot tap on after the cylinder has been heated I get what sounds like a vibration. It generally starts about 1s after I open the tap and lasts for about 1.5s. I've...
2K
British Gas servicing the above boiler ramped up the boiler to maximum in the installer menu to do flue gas analysis. They also measured the working gas pressure on the gas valve test nipple. This fell to 8mbar on maximum and 17mbar on high setting. They then removed the isolation valve under...
Hi. I'm currently estimating on installing a new shower pump to feed an existing bath/shower diverter. Hot side: fit flange and spherical valve and Y strainer to old cylinder, reduce to 15 mm and to pump flexi and reconnect existing hot distributing pipe. Repair shelf in AC and fit twin...
5K
