Discuss Y Strainer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jaydebruyne
Do these restrict flow at all? Someone has fitted 2 x 22mm strainers before a 3 bar shower pump and just wondered if they could be restricting flow (under normal use, not blocked with debris).
If there are now 2 different filters in a line then surely there will a slight loss.
Sorry, bad explanation, so there's one on each cold and hot supply..
No (if anything won't be much )
Changed hose to a large bore hose and new showerhead and custard was happy ;) happy days.. Cheers lads
Reply to Y Strainer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
