Discuss Yellow Hot Water after boiler inspection?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Open vent pumping it's **** off with no cylinder stat, boiled over and made a mess. Turn off cold water run hot tap until it stops then with boiler off leave hot tap running and open stopcock. Do this for 30 mins .
I don't understand how a boiler with no cylinder stat can make the hot water yellow.
No need to get childish, how can a boiler going off on its thermostat rather than a cylinder stat cause the hot water to go yellow.
Ermintrude 701840 said:
Really? I don't understand how a headder tank works either.
I always thought it was a crude urinal for our personal use :)
[QUOTE Halesowen1;701857]No need to get childish, how can a boiler going off on its thermostat rather than a cylinder stat cause the hot water to go yellow.[/QUOTE]
Water in cylinder gets too hot. Expands into tank, stirs up crap, crap ends up in cylinder and into taps.
So you reckon after a boiler service, the Cylinder stat has failed, then the boiler stat has failed??
Must be very unlucky.
Reply to Yellow Hot Water after boiler inspection?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
