Free floating pan
View the thread, titled "Free floating pan" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
I do feel somewhat guilty that most times I post a question on here I have a problem, and today is no exception.
I will try to keep it brief. Yesterday one of my daughters called to say that she had a problem with water dripping through the flat beneath hers ceiling. She had panicked and called out a plumber. A well known firm with a well known reputation for ripping people off which they did until I told her to tell him to go and I would come to see her. Some 4 hours after plodding around the
M25 I duly arrived and she gace me the story. The plumber said the problem was the connection of the cistern flush pipe where it enter the pan. Well that was a lie to start with. The leak was coming from the seal between the parts shown by the arrow in pic 002.
Tightening that connection stopped the leak. So it is/was a right mess behind the tiles concealing the cistern. So I removed on of the tiles to clean it up. I then decided to remove the pan it is just sitting on the tiled floor. How that never leaked is beyond me as
the pan connector and pipe barely mated with the seal in the pipe shown in pic 003. Now recified by fitting a longer piece of p[ipe to the pan connector. Now all this is leading up to my main concern is that the pan just rests on the floor, on a bead of mastic with the mastic all around it. The pan is shown in pic 001 nowhere can I see how to affix it to either wall or floor, am I missing something. Many thanks in advance.
No tbh I don’t like the design either but seem most pans (modern style ) don’t come with fixing holes etc just stuck Down
Ah so I will use the good old trusted stixall then. Like you I would not go out of my way to buy one of these type pans.
Agree much better to either have cistern exposed or go the whole hog and install a frame eg geberit
Totally agree. Years ago I had one which I had bought in France and it attached to a metal frame that had feet and attachments to affix to the wall and the pan then bolted to this. No chance of movement.
And whilst I have you attention may I please ask one mre question. I thought a new pan connector would not go amiss. Thing is I am not happy with the new one as it only has one rubber seal , or shall I say a rubber seal with just one lip. The original has 3 lips which to my mind makes for a better seal. Am I being over cautious ?
Would trust a Mcalpine all day aslong as the glaze is ok on the spigot if not they do one with a jubilee clip on the end eg flexi if needs must
Glaze is fine just do9es not seem to fit as snugly as original. Just read reviews of it, and it is a McAlpine, and others saying same as me that fit if a bit iffy and easy to pull off whereas the otiginal, which I will probably stick with is a really good fit.
Reply to the thread, titled "Free floating pan" which is posted in DIY Plumbing Advice on Plumbers Forums.
Bogart,
Bogart,
