Not sure if someone can answer me this.
Got called out to bleed rads. When I got there bleed them to find them full of water, no air at all.
Elderly customer complaining that rads not hot at top. However the actual rad is an energy saving low service temp rad, of the type flow and return is just in a loop set inside square fins of about 6" square.
Anyway....The flow pipe is nice and hot. The return is quite alot cooler.
Now abviously the rad looses heat, i mean that's how it works.
But I thought the return was only supposed to be 10" cooler than the flow.
Can anyone suggest the factors which might effect the much lower (I'm guessing 20 degrees) temp of the return pipe please??????????
I loosened the head of the TRV, tested the pin was popping out effectively and I left the head screwed back in loosely
Any help much appreciated....Dan
