10 year old Bosch Greenstar Junior water sloshing noise, then fault
View the thread, titled "10 year old Bosch Greenstar Junior water sloshing noise, then fault" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I noticed the boiler making some strange noises last night. It made the same noise previously during a severe winter several years ago when the condensate exhaust which runs into a sink waste outside froze.
I checked the brass spiral filter and purged it and quite a lot of brown debris powder came out, it looked like rust but wasn’t gritty.
I partially drained couple of downstairs radiators with drains on and the water had a few particles and a bit discoloured.
I bled all the radiators.
I refilled from the water loop several times. It still sounds like swooshing water at times.
The boiler works for a few hours but then the error lights come on.
Pressure is good.
I read that the heat exchanger might be blocked with particles after googling the noise.
Ive ordered a Sentinal cleaner arriving on the 28th.
A service is slightly overdue, but it’s been done annually normally. Just booked in on the 29th so i wonder if a service might sort it after the cleaners ran for a few days. I’ve added chemicals before.
Medium term I’m inclined or get an eon boiler grant but I understand there’s a backlog and it cost £350 which I’m happy to pay if this is doomed as I’m quite disabled and don’t like timebombs.
Can anyone perhaps give any advice as the temperatures aren’t freezing so I don’t think it’s the condensate pipe issue again?
thanks
when was it last serviced ?
sounds like it needs to be serviced and a part cleaned (this shouldnt be an extra as its normal under a service)
Best guess on the service is 1 year ago. Maybe a bit longer as covid has screwed things up a bit. Do you think I should get a new one under the grant for 350£? I think I spoke to them 6 months ago when my boiler care was expiring and they said it included power flush, which I know might be needed? I think they fit Ideal which was in the house originally 12 years ago, and that era broke down all the time, but I understand now are very good.
Reply to the thread, titled "10 year old Bosch Greenstar Junior water sloshing noise, then fault" which is posted in UK Plumbers Forums on Plumbers Forums.
Skippydoo,
ShaunCorbs,
