View the thread, titled "110mm elbow spigot to pan connector" which is posted in Bathroom Advice on UK Plumbers Forums.
Hi can I insert a pan connector Finn's straight into the pipe end of an elbow spigot ? I'd rather use this fitting then an elbow with pipe
Many thanks
Put some 110mm into the fitting enough so it’s flush with the front eg the insert / collar depth
And then just push your pan connector in
The socket end of the elbow is going onto the soil pipe, but the other end the spigot part which is just like pipe I'm wondering if the pan connector can go straight into this? I know these ends are made to go into other fittings just like pipe so I assume this will be okay to put a direct pan connector into ?
It's like the male to female 110mm elbow which I attached which I'm using.
Reply to the thread, titled "110mm elbow spigot to pan connector" which is posted in Bathroom Advice on Plumbers Forums.
Thread starter
Joined
Location
United Kingdom
Bathroom Fitter
Thread Information
Title
Prefix
N/A
Forum
Bathroom Advice
Start date
Last reply date
Unsolved
Thread Tags
Tags Tags
None
JonesJ89,
ShaunCorbs,
