15mm Towel radiator valves with 10mm supply
View the thread, titled "15mm Towel radiator valves with 10mm supply" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I've bought a new chrome towel radiator as the old one is all rusty.
I also bought new angled (standard) valves, 1/2" X 15mm as they too are old and rusty.
But when I look at what comes out of the wall, it's clearly not 15mm pipe, looks more like 10mm (plastic).
How have they gone from 15mm valve to 10mm pipe, there's nothing other than the valve as pictured? Is there some kind of insert that I can steal?
How have they gone from 15mm valve to 10mm pipe, there's nothing other than the valve as pictured? Is there some kind of insert that I can steal? View attachment 46291
They used Microbore Reducers, you can see how it's fitted inside of the valve compression side.
15mm to 10mm reducer set photo
15 to 8mm reducer set
Reply to the thread, titled "15mm Towel radiator valves with 10mm supply" which is posted in UK Plumbers Forums on Plumbers Forums.
Laticsforlife,
Elegant Radiators,
