is it similar to 1/2 to 15mm copper then the fittings will work but will be abit tighter?
A lot tighter probably, although I find old pipe varied in tightness slightly. Some 1/2" is just too tight for 15mm solder fittings.
I have loads of inch to 28 sockets. You can get them!
Are 1inch to 28mm couplers available at most plumbers merchants? It's a 1inch incoming water main I need to change place I'm hoping the outside stop tap turns off fully so can solder to it if not, do people think compression is acceptable, its going to be underneath a solid floor eventually.
would it start weeping once connected and tested? Its not like it can be knocked down there.
+1 or primus bottleJust use a hammer.
wuss:yes:Primus? Grandad we use copper glue or push fit. Ever tried hammering a fitting home with a 25 ml plastic tube?
Never happens that man.Stock take Monday!
any one use the bread trick if its passing?
Reply to the thread, titled "1inch copper to 28mm copper" which is posted in UK Plumbers Forums on Plumbers Forums.
