2 cold rads rest ok air lock??????
View the thread, titled "2 cold rads rest ok air lock??????" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
J
jaybob
hi all new to this site so first off hello to all. as this is only my second post i feel abit checky for asking for help so soon on but as i work in the tdrade and havent came across this site sooner you will see me around helping were i can 🙂 im looking for a bit of advise on a problem that has arisen after i replaced a leaking pipe on a ch system. the system has 11 radiators in total boiler is a worchester bosh junior non greenstar, downstairs is fed mostly from drops far as i can see although there are around 3 rads i cannot see pipework for as it is in the walls and all rads have trv's apart from 1.
problem being 2 radiators are cold im thinking 2 things.
1) stuck tr or lockshield (but to be fair since taking off the head to check the pins movment seems fine so less likely this).
2)air lock more towards this as i did have to drain down but sure i have bleed out all air.
note. wen i undo a compression nut or the valves it does pull hot water through although not straight away yet this doest then flow thru rad.
any help much apreciated ive tried all i know and am surre im on the issue just want to collect afew toughts first thanks again 🙂
One or two suggestions, in case you've not thought:
Have you checked for bleed valves in the pipework?
Presumably pump is bled and working?
Have you turned pump up?
Does water flow through with trv head removed?
If you empty rad and remove it, does water come out of trv and lockshield?
You've probably tried all these though!
hi cheers for quick reply. i have checked for blled valvs and used ones i found. pump is bleed and working fine. pump is set to max aready. does not make difrence with the trv head removed and pin was freely moving. to be hounest i didnt go as far as take rad off but this will be the first job in the morning to finaly rule out the valvs.
forgot to mention 1 rad i never touched the valves at all to isolate it as didnt even know it was in the system untill after work done so this one is defo thinking air lock other rad i did isolate though another thing is no other valves stuck or jammed so i defo think air but i cant shift it if it is. never had one like it befoer 🙁 i can normaly get them the thrase in the deep end came to mind lol
cheers for reply only got back from work today to read this. i have sorted now thank you funny enuff i had my wet dry vac and blower as was going to force it through then fort back to when i was working for sumone who had this issue and did what you first suggested and sure as, that did it. infact second job today i had to clear a lock in a single rad after a flush so its a good one to remember 🙂
Reply to the thread, titled "2 cold rads rest ok air lock??????" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
jaybob,
jaybob,
