Guest viewing limit reached
2 Port & 3 Port valve /How do I wire??
View the thread, titled "2 Port & 3 Port valve /How do I wire??" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Delboy
Hi guys I’m new to all of this, any help will be appreciated. I was called out to a job at work today, The system was a pressurised system. The tank was a "ergo" (cheaper version of a Megaflow) tried calling the company, they seem to be nonexistent now. The boiler in the property is a “Baxi Barcelona”.
Whoever did the installation used a Honeywell 3 Port valve…. On the hot water side of the 3 Port valve they have also installed a Honeywell 2 Port valve, with all the wiring ie: valves, pump, stat etc all going into a wiring center.
My problem is that I ‘m not one hundred percent sure how to wire a system that consists of a 2 Port and a 3 port together… I’d be fine I’d it was a normal 3 Port system or two separate 2 Port valves… any help, explanations or directions to websites would be appreciated…
Thanks guys😕
If you can do 3 port/2port you are ok. The only diff is that you will have 2 stats for heating, as it is zoned???
Ive not done my unvented yet but i think the 2 port is linked to the overheat stat to cut the supply should the cylinder overheat so i wouldnt touch it if your not sure
Mikegas.... I dont think there is a fault with the wiring, the initial problem has been solved.... my issue is that I have never been showed how to wire a system like this, I'm trying to work it out to help me in the future incase I come across this again..
Thanls..
The 2 port valve is the energy cut off (eco) and is a safety feature which is always incorporated when wiring up a "y" plan (3 port valve) unvented cylinder system. You need to have your G3 unvented ticket to play about with these. If you do the course it's explained there.
Thanks ecowarm that is exactly what I was looking for... you hit the nail on the head.... Thank you to all the other engineers.. youve been a great help!!!
Reply to the thread, titled "2 Port & 3 Port valve /How do I wire??" which is posted in UK Plumbers Forums on Plumbers Forums.
Delboy,
Delboy,
