View the thread, titled "2 Port Valve Closed Question" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I have a honeywell 2 port valve to the emersion tank which is allowing water to pass through on the closed position meaning the water is boiling hot.
A previous plumber left an old port valve in cupboard which I took to bits to see how it works. 😀
I thought the seal must have gone inside but after looking at old one it appears very little can go wrong with the rubber ball.
So could this mean my problem is more likely to do with the springs or motor not giving enough pressure to hold rubber ball against the valve ?
I know easy option is buy complete 2 port valve assembly but I'm quite interested to find out more about these sorts of things.
Any thoughts on this really appreciate
Thank you
Presuming it is in the right way round, it might be worth taking it out to inspect it prior to buying another.
If you have had 2 there may be a reason they are failing.
I have in the past seen them distorted or coated and that prevents them seating correctly.
Reply to the thread, titled "2 Port Valve Closed Question" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread starter
Joined
Location
Highlands
Other Plumber
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Unsolved
Thread Tags
Tags Tags
port valve
Stratf01,
MikeJhn,
