View the thread, titled "2 port valves or 3 ports valve ??" which is posted in Water Underfloor Heating Advice on UK Plumbers Forums.
Hi guys
Is it better to have two 2 port valves or one 3 port valve to control the flow to either dhw or underfloor heating ? Cheers
2 ports least then if one fails you don’t loose both eg if hot water fails you have heating etc
It's what I'm most used to and it works so I stay with it.
As good a reason as any , ok Simon on the system already it has a flow obviously from hear pump to cyclinder , before cyclinder it t' s off one side to heating , other to dhw, on the dhw side into the cyclinder it already has a 2 port fitted to stop gravity circulation when heat pump is off , can I use this to do both jobs ? Stop gravity circulation and control dhw ?if I can all I have to do is put a 2 port on the heating side ??
If it’s the flow to the heat coil then yes only need one more
Yep it has the existing 2 port on the heat coil flow, that's brill news , thanks very much , I might be in contact again , trying to finish our new build install, plumber very kindly went bust and decided to go at insulation installation instead 🙄
Reply to the thread, titled "2 port valves or 3 ports valve ??" which is posted in Water Underfloor Heating Advice on Electricians Forums.
