2 way 2 zone valve question.
View the thread, titled "2 way 2 zone valve question." which is posted in UK Plumbers Forums on UK Plumbers Forums.
J
Jhonesy
Hi I have a honeywell programmer which does 10 min cycles but with the zone valve fitted it is closed during a 4.5 min long pump only cycle. Is there a way to stop this and only close when pump stops. It is open during heat and pump part but you can gradually loose a warm rad with it not pumping the water round enough when warm.
Reply to the thread, titled "2 way 2 zone valve question." which is posted in UK Plumbers Forums on Plumbers Forums.
Jhonesy,
Murdoch,
