2 Zone system ??
View the thread, titled "2 Zone system ??" which is posted in UK Plumbers Forums on UK Plumbers Forums.
bgec
Hi all
I would like to split my heating system in half to have 2 room stats one on one side of the house and one on the other
I have a gravity system 1 zone valve please help me where to start thanks
yeah can be done your going to need a new flow pipe from the plan back to the new circuit
Thanks for the sensible reply. so if im right what your saying is create a new flow to the new ciruit split the existing flow into 2 and fit a zone valve on the 2 flows ?
then i can have 2 stats ?
What are the potential problems will i need to keep the programer set to constant ?
Thanks again
made me chuckle
no really there seems to be an ever increasing no of people posting how to do something that thay havnt got a clue about
look through some of the recent posts thay are compete and utter rubbish
Yes i get your point maybe i didnt come across very well short and sweet maybe
But i have more of a clue than some i am a fully qualified Electrican and this will not be the first central heating system i have installed
just wanted some pointers
Yes, what you should do is look at the honeywell website which will give you loads of info.
If you have a programmable room stat the heating on the time should be on 24/7 the room stat does the job.
If you have 2 room stats you can also/will need to buy another gizmo to stop the boiler cycling on and off continuously. The gizmo (forgotten what its called) will only allow the boiler to cycle so many times in an hour (6 I think not too sure)
There are so many on the market its difficult for anyone on the forum to answer all your questions. The options are huge with new products being developed continually.
HR80UK for eg. is battery powered radiator controller .
HC60ng relay module is wired to the boiler or heating valve in Y or S plan. HC60NG will switch on when it gets a demand from HR80UK.
Why wouldn't you just fit TRV's probably the cheapest option.
So, although "get a heating engineer" may seem a bit harsh, its probably the wisest thing to do due to many variables...... even space in the airing cupboard may be an issue.......😱
made me chuckle
Isn't that the point of a forum ????? we are not born full of knowledge we learn from others so why try to put people off the forum.😕
In reply to the original post why not just fit rad stats would be so much easier and more controllable to each room 😉
Here here to your first point. As for stat valves there is a ladie in the house so they will be turned up all the time im not starving but i have no money tree in the garden
Thanks for all your help that makes things clear
Best practice is boiler interlock, TRV's and a programable room stat if you want to comply to up to date literature.
To answer question, x3 zone valves, two to heating, one to hotwater still only one return needed for heating though. Exactly like a normal S plan but with an additional valve. And if your an electrician the wiring will be a peice of cake.
You could upgrade the system to CM Zone (Google it) - no need for pipework changes, but programmable time/temperature in each zone using wireless signals.
Reply to the thread, titled "2 Zone system ??" which is posted in UK Plumbers Forums on Plumbers Forums.
bgec,
Rox,
