22 fault code, Glow worm
View the thread, titled "22 fault code, Glow worm" which is posted in UK Plumbers Forums on UK Plumbers Forums.
billski
Got a Glow worm 18 flexicom with f22 fault.
I've replaced both flow & return thermistors, bleed all rads of air, removed the pump and cleaned it, it all seems fine and pump is strong, checked wiring continuity and that's all good. Boiler is only 6 years old and Glow worm have said it sounds like the main heat exchanger is blocked causing a restriction. Apparently they are prone to this. They don't sell a gasket kit to remove it and clean it so they've suggested I'd have to replace it! Probably better to replace the whole boiler, but it's only 6 years old.
Any one suggest anything else?
I've cleaned out the condense trap as well.
Electrodes fine
What’s the fan pressure like against manufacturers listing
It can’t be serviced??
Does this model have a stainless heat exchanger or Ali type?
You could try jet flushing it with x400 or x800 disconnect from the system in this case, if it works then maybe consider doing the system to . Kop
Reply to the thread, titled "22 fault code, Glow worm" which is posted in UK Plumbers Forums on Plumbers Forums.
billski,
king of pipes,
