Y
Yamahayzfr6
Just about to have a 30+ year old gas boiler replaced, and would appreciate any advice on whether I need 22mm or 28mm pipework on the flow and return....
The existing boiler is fairly central to the house, it is sited off the hall close to the bedrooms, far from ideal, so the new boiler will be sited at one end of the property, in the garage. It is a Bungalow circa 20m in length, all radiators are on one level... The boiler will be sited in the garage which is split level, below the rest of the house, so the top of the boiler is virtually level with the flow and return pipes....
The flow and return pipes will be approximately 15m in length each, with only one 90 bend in each circa 2m from the boiler....
The new boiler is going to be a Worcester Bosch 42CDI combi (unless anyone thinks otherwise), and there are 6 x large, 3 x medium, 2 x small radiators (all doubles) + an heated towel rail / small rad... Existing pipework is 22mm, but it has been suggested that I may want to consider 28mm... "for better flow"...
Is 28mm neccessary ? considering the high cost of 28mm pipe and fittings I am thinking of trying the existing 22mm and then if there where any issues, I could always fit 28mm if I had too...
Any help, very much appreciated...
